I know that the new PS3 firmware will display xvid videos. I have an xvid that I just cannot get to work. I keep getting "Unsupported data" when I try to play it on the PS3. I have been able to get other video files to stream successfully, but I cannot figure out why this one won't work. Below are all the details of the file:
Format : AVI
Format/Family : RIFF
File size : 699 MiB
PlayTime : 1h 25mn
Bit rate : 1138 Kbps
StreamSize : 7.84 MiB
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1852/release
Video #0
Codec : XviD
Codec/Family : MPEG-4
Codec/Info : XviD project
Codec profile : Streaming Video Profile/Level 1
Codec settings/Packe : Yes
Codec settings/BVOP : Yes
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matri : Default
PlayTime : 1h 25mn
Bit rate : 992 Kbps
Width : 640 pixels
Height : 336 pixels
Display Aspect ratio : 1.905
Frame rate : 23.976 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
StreamSize : 610 MiB
BitRate_Nominal : 982107.980
Audio #0
Codec : MPEG-1 Audio layer 3
Codec profile : Joint stereo
PlayTime : 1h 25mn
Bit rate : 133 Kbps
Bit rate mode : VBR
Channel(s) : 2 channels
Sampling rate : 48 KHz
Resolution : 16 bits
Video0 delay : 4s 845ms
StreamSize : 81.9 MiB
Writing library : LAME3.93
Encoding settings : VBR (mtrh)
Could try this
Until now i havent encoutered a divx file that doesnt play or that i cant make it to play. Bleach, movies or anything plays just fine. If it doesnt play or like bleach files that only plays for 6 secs. You just have to modifie it download the MPEG4 Modifier from http://www.moitah.net/ check the unpack bitstream and there u go problem solved. It takes less then 10sec for a 24min anime ep, it basicly just change a little thing in the coding. It such simpel thing, rly lazy that sony didnt ad something to fix this. Or maybe they didnt want it to work... T___T
This was a post I found on another forum as I have a similar problem but the files I tested didnt have a packed bitstream anyway, may work for you as it shows a packed bitstream. -
Actually, I'm not sure the PS3 has a problem with packed bitstream. It didn't mind any of the test files with packed bitstream I used, anyway.
If cameras add ten pounds, why would people want to eat them? -
I have checked my files and likewise some files work with packed bitstream so that cant be the killer. I am desperate for a simple solution to this. I want a procedure to run thorugh to standardise the file without any encoding. Dont mind if it takes a while but I dont want to lose anymore quality, I find a lot bad enough already.
I got advised to run the file through auto gk and select the option for standalone compatibility which I did but the quality did seem to suffer to me but hard to tell on pc monitor, my tv is 1080p plasma 42inch so need as much quality as poss. This also took over an hour and a half to complete a 40 min clip so must have reencoeed.
I have just posted this question in another thread but is there a way to demux/remux the file in a different container or format to make the ps3 play it without further encoding. (that might be a stupid question but not sure about this step) -
/Mats -
I did read that this process worked when file says cant be played and gives an error number not when corrupt. It did work for that but I havent tried it for this but i will give it a go.
Ripping DVD Collection then Stream to PS3
By Macdaddy4sure in forum DVD RippingReplies: 1Last Post: 31st Dec 2011, 04:06 -
Any software that can stream to PC and PS3 on a LAN simultaneously on XP
By gll99 in forum Video Streaming DownloadingReplies: 5Last Post: 24th Jul 2010, 17:09 -
Rip DVDs to my HD so that I can stream them to my PS3
By joegeis in forum Newbie / General discussionsReplies: 18Last Post: 11th Oct 2009, 17:47 -
Got ripbot working, BUT it wont stream to my PS3
By Fiostech in forum Blu-ray RippingReplies: 5Last Post: 5th Feb 2009, 12:15 -
Can't Stream An XVID file to PS3
By CrazedSyko in forum Video Streaming DownloadingReplies: 3Last Post: 19th Jul 2008, 10:48
