Hi
Recently i had bought my boyfriend a Magnavox MWR10D6 DVD Recorder.
It works fine when recording and playing on its own.
However when he inserts a Homemade DVD that he made with DVD FAB
Most of the movies are choppy but only on this Magnavox Machine
and on no other DVD Player.
We had called tech support,and they had said they never heard of any problems but to try
and use usa region codes only.If thats the case why is it some movies dont play choppy and others do
And if i must change the region Code of a Disk how do i do that so it wont play choppy
on the Magnavox Machine
Or is there something else someone here knows so we can work around this proble,
Please help
Thank you so much
Region code won't affect playback. It either accepts the disc or it won't. DVD's that you have burned yourself have no region coding anyway.
Most likely the issue is related to the media that you are using. Some players are very picky about the brand/type of media that they support (Sony for instance). Try a different brand/type of media. Verbatim and TY are the most reliable. Either way, it will be a matter of trial and error to find which brand(s) work best with that player.Google is your Friend -
Hi
Thank you for your very speedy reply
Remeber im not recording from the player but from a Pc as a test
Store bought Dvds are not choppy at all but most home made ones are
W have used for example an RW dvd disk many times
for experimental and educational purposes only.
Some movies are choppy and some are not.
We also had tried it with an R Disk,And most of the collection we have
are not choppy at all using the same brand disks for each movie
But then again some are Choppy,So we cant exactly claim
now the Player does not like the Disks if Some movies play god and others dont -
The fact that the discs play normal in other players, indicates the discs are recorded properly. The fact that commercial discs play in the recorder, indicate the recorder is likely not having any hardware playback issues. In other words, the discs themselves are fine and the player is fine.
So the only likely option left is that the player doesn't like the media you are using. It doesn't matter that some work and others don't (same brand and type).Google is your Friend
Magnavox MWR10D6 - Cannot Record
By Kat9119 in forum DVD & Blu-ray RecordersReplies: 16Last Post: 10th Sep 2010, 13:12 -
why can't I play my burned dvd's on my Magnavox mwr10d6
By totalyscrewedup in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 11:35 -
Magnavox MWR10D6 - Help with Playback on other players
By Stephgriffin74 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jan 2008, 13:35 -
Help with Magnavox MWR10D6
By JoeDirtGR in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jan 2008, 01:07 -
Magnavox MWR10D6
By Fathead31 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Dec 2007, 22:04
