I tried to save some .AVI file with new audio compression...
so i choose "Lame MP3, 48000 Hz, 128 Kbps, CBR, Stereo"
but when i try to save it - i'm gettin this massage:
OK...
so i went back to "compression", this time pickin "Lame MP3, 44100 Hz, 128 Kbps, CBR, Stereo"
this time it worked...
why does VirtualDub resist to 48000 sample rate?
does 48000 sample rate is better quality then 44100?
Thanks in Advanced!!!
This means the original audio in video file has 44.1 sample rate and the mpeg encoder doesn't perform resampling to another value.
There's no quality gain with going 44.1 => 48, it is only done if one wants to make the audio DVD compatible. Original sampling at 48 is a bit better since it allows for keeping wider audio frequency range (up to 24kHz theoretically).
How to change sample rate in FFMPEG
By MackanZoor in forum AudioReplies: 5Last Post: 24th Jan 2011, 14:31 -
Yet Another Sample-Rate-Conversion Tool
By El Heggunte in forum AudioReplies: 2Last Post: 11th Dec 2009, 20:57 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
DVD Audio To .wav Sample Rate Question
By xtreme469 in forum AudioReplies: 3Last Post: 29th Sep 2007, 10:04 -
inconsistent audio sample rate error in FCE...
By ednarophati in forum MacReplies: 1Last Post: 23rd Aug 2007, 14:59
