I was wondering if anyone had some software they used to schedule a capture. I use VirtualDub and downloaded a program called "LaunchPad" it is very basic, but I was able to make it send c to start a capture and space to end one. I'm wondering if anyone had used a more advanced methods, so maybe you could capture for an hour, use different name and capture for another, etc.
I us a diferent program called AVIIO. It has a built in timer. It uses 24 hour format but easy to use. Simply set the start time and how long to record. Nice that I can save a setup with both the timer and setting and just recall then when I need it.
It also, I assume if its a TV card, can change the channel. I use a DC10 card so this part of the feature has no effect for me.
NightWing -
hmmm, I have a Pinnacle Studio PCTV Pro and AVI_IO can't seem to find any channels hmm.
Have basicaly all shows I tape { tape? } with there own setup. Helps for Adult Swim and Midnight Run since the good shows are at 12pm or when I just get too busy.
Good luck
NightWing -
Since I have a DC10 card it has no channels. Not sure if I ever tried it with the I/O Magic 39 dollar wonder card.
I asume that with the label and field that it does if you have a tv card.
Good Luck
NightWing -
For VirtualDub, I use VDStart (www.sssoft.net I think). It has a clunky interface, but works fine for me. It has the ability to rename the captured files after it stops, so I guess you could run multiple instances of it and have each set for different times and rename the captures to different names so as not to overwrite the previous, but I don't use that feature so I'm just guessing
For general time-x to time-y capturing it works great.
VirtualDub jobs -- how to schedule them ?
By ralf07 in forum Newbie / General discussionsReplies: 1Last Post: 5th Nov 2011, 16:27 -
Using rtmpdump to schedule record and reconnect?
By RedPenguin in forum Video Streaming DownloadingReplies: 1Last Post: 4th Jul 2011, 23:04 -
DVB-t300 schedule recording problem
By sharkbite in forum DVB / IPTVReplies: 0Last Post: 23rd Aug 2009, 18:59 -
winfast palmtop TV external card - the schedule not working
By 3l8x in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2008, 15:14 -
Easier way to schedule captures
By 4evrplan in forum Capturing and VCRReplies: 6Last Post: 3rd Oct 2007, 23:04
