What's the best software to join together video clips (DivX)? Will Virtual Dub do this?
thanks
It can (Append), although there is always a risk of audio sync issues in the second half (post join).
I have found AVIDemux to be more reliable with audio, although on occasion the join point can slow down visually for a second or two.
In short - I have found no guaranteed way to join two clips with perfect results every time.Read my blog here.
The video in question has no audio. It's just got video. So i think it would be easy to join two together. What i did was, to take the primary video, and mix things with another one. I used software to make another video that mirrors things, so the subjects are facing the opposite direction. So now i have two different videos that are the same, but the subjects are facing left in the first one, right in the second one. I don't wanna have it where the primary video plays all the way through, and then the second video plays. I wanna mix things up, where the primary video plays 5 seconds, then the second video kicks in and plays 5 seconds, and so on. I know it may sound like a bit of a project, but this is what i wanna do. Have any suggestions?
thanks! -
You can do it in either by loading and trimming the video multiple times, or create a script for avisynth that uses the Trim() statement and adds the pieces together. Or use an NLE if you have one. Even Windows Movie Maker can do what you ask.
Read my blog here.
Software to join .ts(avchd) and .mp4 video files without re-encoding
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Oct 2010, 10:07 -
How to join clips in Mpeg Video Wizard? (Thanks)
By seymoria in forum EditingReplies: 5Last Post: 29th Jan 2009, 13:23 -
join multiple video files - free software?
By kj1983 in forum EditingReplies: 2Last Post: 21st Aug 2008, 11:54 -
Recommendations for database software for my home video clips
By lariol in forum Newbie / General discussionsReplies: 0Last Post: 9th Jun 2008, 13:49 -
Batch Join Video Clips
By kompressaur in forum EditingReplies: 2Last Post: 5th Dec 2007, 21:27
