Hello,
On Virtualdub whenever I encode with the setting on xvid 2pass - 2nd pass I get an error saying "statsfile not found" then virtualdub crashes. I only get this error when using 2pass - 2nd pass.
I have searched the forum but I have not been able to find out what is causing this.
Sometimes it does work sometimes it doesnt, and when it does work, ussually on the output file the audio is out of sync.
Thanks.
Edit : I seem to have fixed it, If I encode with 2pass - 1st pass then encode again with 2nd pass - 2pass it works. To save time isnt there a way to encode the 1st pass and 2nd pass at once? I mean without having to encode again and replace the file?
Thanks Again.
Hi-
Yes, save the first pass to the Job Control (check the "Don't run this job now" (VDubMod) or "Add operation to job list" (VDub) box when saving). Then set up and save the second pass. Then go to the Job Control and start the first pass. It's explained in the bottom third of this guide, with pictures:To save time isnt there a way to encode the 1st pass and 2nd pass at once?
http://www.doom9.org/xvid-vdub-final.htm
Virtual Dub 1st & 2nd Pass Encoding
By OrchestraAndChoir in forum Video ConversionReplies: 10Last Post: 22nd Jul 2012, 07:20 -
x264, point of 1st Pass encoding?
By Sephisto in forum Video ConversionReplies: 50Last Post: 18th Apr 2012, 01:13 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
1st and 2nd Pass with VDub/VDubMod when cutting out frames.
By Chakra in forum Newbie / General discussionsReplies: 20Last Post: 11th Mar 2011, 17:45 -
Removing subtitles, running 1st pass again?
By moviebuff2 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 06:20
