Is there a way to import video from a copyrighted DVD into a Mac for use in Final Cut Pro. I would like to make some tribute videos and need to know if I can do this.
THANKS!
Results 1 to 9 of 9
You would have to rip them first, to remove the protection. MacThe Ripper should be able to do this.
Read my blog here.
Once ripped, run the .vob files through MpegStreamclip
(make sure you also bought the QT MPeg-2 component,...oh wait,
it should have come legit with your copy of FCP), and then
convert these to .DV Stream files.
Once done, import those .DV Stream files into FCP."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Technically if you only want the video, you dont with FCP Studio. It will have to be converted, however, to whatever output format you desire. So yes, you have to throw away a generation -- but it wont make it worse if you convert to a format like Pixlet or Uncompressed.
A general tip - most of the time when a tool is mentioned in a post, the name of that tool becomes a link to it's page in our Tool's section. There you will find links to download it, links to guides, and user comments on the program itself.
Try clicking on the name in my post (above).
Another thoughtful feature from our host, Baldrick.Read my blog here.
Urban Mac User
Final Cut Pro 7 exits when importing avchd folder
By jovannig in forum EditingReplies: 0Last Post: 23rd Jan 2010, 17:24 -
Final Cut Importing Woes (non-DV files)
By panhype in forum MacReplies: 2Last Post: 15th Jul 2009, 16:20 -
Strobe importing VHS to Final Cut Pro
By Huntr777 in forum MacReplies: 0Last Post: 15th Apr 2009, 14:59 -
Importing VOB files--iMovie, Final Cut Express? New to Mac
By Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 08:54 -
importing commercial DVD's to final cut
By aquafinity in forum Newbie / General discussionsReplies: 0Last Post: 24th Jul 2007, 16:31
