I took a 59M avi file (2 min 20 sec) into VirtualDub and kept the first 12 sec, about 2500 frames, or so. When I try to save it as AVI, it shows that it will become something much larger than the 59M. What's going on? What do I need to change? Options?
Direct Steam Copy mode will just stream the chosen section to a new file without re-encoding - with caveats : no filters, and you must cut on key frames.
Otherwise, go to Video->Compression, and chose a codec and compression settings for the new clip.
If you use the latest beta version then you can use smart re-encoding, which will encode only the open GOPs of a clip, and Direct Stream Copy the rest. That would be the best option of the lot.Read my blog here.
Virtualdub output
By DuBsTaR in forum Newbie / General discussionsReplies: 1Last Post: 7th Dec 2011, 13:53 -
Reformatted..now all output videos with XMediaRecode are too large
By smackyourfupa in forum Video ConversionReplies: 2Last Post: 25th Nov 2011, 17:34 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 19:27 -
Virtualdub made my movie too large
By Belfour in forum EditingReplies: 3Last Post: 14th Aug 2007, 04:59 -
Avisynth on Virtualdub too large
By mrcoolekin in forum EditingReplies: 6Last Post: 11th Aug 2007, 11:11
