Hi all,
First-time poster here, so please excuse me if this question has been answered before, as I searched the forums but couldn't find a good solution:
I have created a DVD but it won't seem to play in my stand-alone DVD player connected to the TV. It works fine on my computer's DVD/RW drive, though.
The DVD was created with WinAVI Video Converter. The media is Memorex 4X DVD+RW. My stand alone player is a Sony DVP-NS425P. It has a sticker on the front that says DVD-RW/-R and DVD+RW/+R so I assume it should be able to play the files. The DVD burner on my Dell XPS is a TSSTcopp DVD+-RW TS-H653A.
Any idea what I could be doing wrong? Audio and Video_TS folders are on the disc, VOB files are there, and as I said, it works fine on my computer's drive.
Thanks for any advice.
Lorne Lavine
Well I guess the first step would be to try other media (discs), not a rewritable.
Well, according to the guide available on this here site, your player can in fact play DVD+RW, so that is likely not the issue. But as a future reference, do not assume it can play something just because a sticker on the player says so. That often results in heartache.
Without knowing your exact authoring/burning method, it is hard to determine whether that might be the problem. I have always found TSSTCorp drives more than just a little suspect after having burned several things on them, but that's just me.
Point being, a bit more information might help us determine the cause."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Thanks for the advice. Turns out, if I had looked at the TV screen, I would have had more information: it was a region coding issue. Installed DVD Decrypter, patched it to Region 1 (the Sony seems to have problems with Region-Free or MultiRegion coding), and all is well now. I've created about 10 DVD's now, no problems to speak of.
Thanks again.Lorne Lavine
DVD won't play
By BLSAMPLES in forum Newbie / General discussionsReplies: 5Last Post: 24th Sep 2009, 23:20 -
dvd won't play have i lost what is on it?
By CALLOHAN in forum Newbie / General discussionsReplies: 3Last Post: 6th Jul 2009, 04:15 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 19:57 -
DVD won't play
By Golgo13 in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2007, 16:40 -
one particular DVD won't play on my PC
By moe_b_disc in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2007, 06:20
