I bought an old classic DVD release, only to find it was a 'colourized' version.
I wanted a B/W copy so I made one and it plays great on the computer player, but is choppy (during fast motion) on my two set-top boxes.
To make the B/W, I used TDA to make one large .mpg file, then opened it in Virtual Dub and used the grayscale filter to make an .avi file. I processed about one third of the file at a time, as the .avi's were huge.
Once I had all the .avi's in B/W, I used Super to convert them to .mpg's and then loaded each .mpg into TDA again and burned a disk. It played great on the computer player, but was not so great on the set-top player when the scene showed fast movement.
Any ideas why this only plays poorly on the set-top players? I used an 8X TY blank, burned at 4X, using ImgBurn.
I tried this process twice with the same results and I'm stumped.
AnonymousGuest
We don't know enough about your process to know exactly what you did, but here's my best guesses.
1) You encoded the wrong field order - you either did bottom field first when you have should done top field first or vice-versa.
2) Your final bit rate may be too high for DVD specs and your standalone DVD player.
Super is OK, but I can't recommend it for encoding to DVD. CCE, HC and TMPGenc would all have been better choices.
how to burn avchd on dvd-r in high definition for BR set top playback?
By masterpug in forum Authoring (Blu-ray)Replies: 32Last Post: 15th Aug 2010, 17:47 -
Ripping To HDD For Media Extender/Set Top Box Playback
By Satchmo in forum DVD RippingReplies: 8Last Post: 18th Feb 2010, 18:25 -
NO DISC on set-top players - dvd replication
By wzt in forum Authoring (DVD)Replies: 16Last Post: 25th Sep 2009, 11:15 -
DVD/Divx/USB (2.0preferably) set-top players
By celchlepp in forum Newbie / General discussionsReplies: 20Last Post: 13th Mar 2008, 17:10 -
Subtitles wont/don't display on set top players
By scamuel in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 24th Jan 2008, 08:31
