Hi,
I have a HP 9060N Computer with a LightScribe combo HD/Blu Ray drive in it. I have installed DVDFab HD but it will not read/open any HD or Blu ray disc that I put in. I have tried 4 of each variety. The computer comes installed with "DVD play" which I think is HPs proprietary HD player software, I wonder if that is causing a problem. I can rip normal DVDs no problem. Anyone have any ideas?
Results 1 to 20 of 20
Do you have the latest version of DVDFab Decrypter? Is the computer/DVDrom recognizing the disc without DVDFab running?
Google is your Friend -
I guess you have tried latest dvdfab decrypter beta? Or maybe try anydvd instead.
well if it helps on a somewhat related note. Any dvd I made on the jvc drm100s homedeck recorder does NOT load up or even be regonized by the computer when using any version of dvd fab decrypter. I actually have to use the old dvd decrytper or copy/paste to put the files back on my pc.
Blueray & HD disc cannot be viewed on DVD-rom... You need a HD/Blueray drive. Only then will DVDFAB or AnyDVD will work... :shock:
Originally Posted by d1spyky
you obviously did not read the first post:
"I have a HP 9060N Computer with a LightScribe combo HD/Blu Ray drive in it"
and in my case, the jvcdrm is a dvd recorder. dvd fab decrypter does not read dvds made in that machine (at least not mine). The shock is that you need to read better -
Thanks very much for the response - yes I have the most current version of DVDfab running.Originally Posted by Krispy Kritter
Yes the DVDrom is working perfectly with the supplied software. I can rip standard DVDs in that same rom with DVDFab no problem. It just will not recognize any BD or HD DVD disc I put in the drive. It shows it as empty. -
What is the make and model of the burner?
I was under the impression that Fab does not support BD discs. As to "reading" the discs, Windows cannot do this without a UDF-2.5 driver installed, so they will always be absent in Windows. Although the provided PowerDVD should be able to play them.
Unless this drive burns BD, it is a LG GGC-H20L. -
[quote="Krispy Kritter"]What is the make and model of the burner?[/quote
From HPs spec sheet -
Blu-ray/HD DVD player(5b) & SuperMulti DVD burner with LightScribe Technology(5a) Write -
- 16x DVD±R, 8x DVD+RW, 6x DVD-RW, 4x DVD±R DL, 5x DVD-RAM, 40x CD-R, 24x CD-RW.Read
CD-RW.Read - 6x BD-ROM, 3x HD DVD-ROM, 16x DVD-ROM, 40x CD-ROM
I am pretty sure since it is a lightscribe that must be an HP brand drive? I am at work so cannot check device manager to see what it shows - but will do so later.
Not sure if this helps. -
The Drive I have is an LG BluRay and HD-DVD combo plus DVD writer, but not a BluRay burner. Do I have to replace it with the BluRay burner, in order to transfer my BluRay discs to my HD?
Thank you so much for your responses. -
No - all you need is a dvd rom to rip movies to a hard drive.Originally Posted by HTLover
According to the Device Manager it is a GGC-H20L. I believe this is the LG drive. Hope this helps.Originally Posted by Krispy Kritter
I am having the same problem. I cant remember where but i thought i read somewhere where dvd fad wasnt going to support the hd-dvd and blu ray decryption for a while. il try to find where i rad it but im not 100% sure so check around
http://club.cdfreaks.com/f116/hd-dvd-blu-ray-support-210293/
Not sure what it means -
That correct DVDFab HD not reading BD disks, I have LG superdrive on my comp and all crap to read and write BD and HD, not reading!!. They fool people, AnyDVD HD does perfect backup to hard drive, but to fit it to 25G BD-R disk nigtmare, only the way to transcode the main move, but most of programs get stock during transcoding.
Toshiba SD-290 - Not Reading Burnt Discs (I've read the sticky)
By irish-sid in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Feb 2011, 10:06 -
Any tools for copying / reading bad quality discs?
By Locut0s in forum DVD RippingReplies: 2Last Post: 12th Nov 2010, 09:06 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 01:25 -
problem reading some discs
By nick6878 in forum DVD RippingReplies: 5Last Post: 3rd Jan 2008, 11:25 -
Panasonic ES30V Stopped Reading blank discs
By newshoes in forum DVD & Blu-ray RecordersReplies: 5Last Post: 25th Oct 2007, 16:50
