The last four or five times that I have started my computer, an installer pops up and tries to install a program called Photo Gallery. It gets to the point where it needs a CD and I have to hit cancel over and over until it gives me a .netframework error that I have to control, alt delete to get out of.
I have no idea what this program is or why it just started trying to install itself every time I start my computer. I've checked HiJack This but don't see anything in startup that would cause it.
Solved: Double clicked on the HP Digital Imaging Monitor in my system tray and the Installer popped up so I put in the Printer CD and it installed the program. Not sure how it got uninstalled unless Nero uninstalled it to install something called Image Drive.
HP printer driver discs put a whole lot of programs on your computer by default.
They also have a bad habit of continually checking to see if you have the very latest versions of them all. Fine if you are using them all. If not, maybe a custom install would be a better choice.
I hate HP drivers/programs, especially the all-in-one printers
I always avoid the full install of their junk. I'll install the printer, then when XP/vista asks for the dirvers, I point the the specific drivers on the disc. I never use the setup routine or auto-run on the disc itself -
I buy canon instead of hp for that reason.
I'm not as picky as you.Originally Posted by stiltman
I hate 'em all!
HATE!!!
Though, our most recent is an AIO and it certainly sucks worse than previous HPs we've had."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
pc startup problem
By janefield in forum ComputerReplies: 3Last Post: 22nd Feb 2009, 12:09 -
Unwanted captions showing up at startup duped DVD
By juststarting in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2008, 01:47 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
Errors on startup
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd May 2007, 06:14 -
Error on startup
By bush in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 22nd May 2007, 19:30
