When I use Tscv and make my menu with chapters
I then create a bin/cue file and I only get the cue file.
No bin file is made. I use fireburner and the icon of the cue file is a fireburner icon I click on it and then fireburner opens and is looking for the bin file, which is not found.
Besides using tscv is there another software that I can make menu and chapters like this one?
Try this.
Using TSCV generate the XML file and save it.
You can use vcdxbuild ( www.vcdimager.org ) on this XML file to generate BIN/CUE. -
does vcdxbuild have a gui???
I used vcdimager but it only inputs with mpegs? no xml? -
Are you sure you don't get the bin file too? I ask because some programs have trouble reading the cue file. For example:
File "C:\my documents\my videos\American Pie.bin" Binary
can't be read, you need to change it to:
File "C:\mydocu~1\myvideo~1\americ~1.bin" binary
So, open you CUE file and change the line to DOS 8.3 nomenclature and see if that fixes it. Also, you might want to d/load CDRDAO and allow TSCV to just burn your bin/cue files for you. -
Oops No. vcdxbuild is a commandline app and applications like TSCV and VCDEasy are their GUIs.
You could try running this as follows
Code:vcdxbuild -b c:\cd.bin -c c:\cd.cue mycd.xml
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
