Hi,
I'd like to uninstall a DVD burner I have (Pioneer DVD-RW DVR-111D) to put it in a newer system. Do all I have to do is uninstall it via the Device Manager, make sure it's gone from My Comp, and take it out after shutting down? Don't want to get any surprises... Thanks...
you don't have to remove it from device manager. just physically remove the dvd burner from your old computer. then physically install it into your new computer. make sure you have the jumper setting on the drive correctly which would mean either set it to MASTER or SLAVE setting.
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 08:31 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 16:09 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 15:59 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 10:55
