I've got my DVD all set to go but when I check for errors I get "end action not set" and when I test play it, it just stops at the end. I guess that's the error. What I would like to do is have it finish playing and then return to the menu, but I haven't been able to figure out where to set that.
I'm using encore 2.0 one timeline and 14 chapters if that helps.
Results 1 to 9 of 9
Firstly, I don't use Encore so I couldn't tell you exactly what the process is. But all you need to do is link the end of your last chapter to whichever menu (main, chapter or scene, etc.) you'd like. This should be pretty easy, I think (again, I don't use Encore). But will give it a shot.
Try clicking on the last chapter (on the timeline??) and right-click -- see if there's something that says "Set End Action" or something like that. If there is, select it and choose which menu you want to link it to. Or, try clicking on the last chapter (on timeline?) and find the dropdown menu called Properties. Do the same thing, try to find something that says, "Set End Action".
Sorry can't be more help. -
I would recommend setting the END-ACTION for the Timeline/Title (rather than set the END-ACTION on the last Chapter on the Timeline).
Regards,
George -
I couldn't find that option - was the first thing I looked for when I saw the error.Originally Posted by GeorgeW
I'm away from my editing machine ATM (so going by memory). Double-click on the Timeline, and on the right side (using the Encore Default Layout), there should be options for the Timeline (one of them being the END-ACTION).
I'll look for the exact position later today when I get back to my editing machine...
Regards,
George -
Hi,
Sorry to have to resurrect this old thread, but does anyone know how to set the default end action in Encore?
I often have batches of up to 20 DVDs to do and having to waste time setting the "end" action and the "menu button" action every time is really irritating. I also use Grass Valley/Canopus Edius and that just burns DVDs with no hassle at all (though it does have its own, errm, "quirks")
Thanks! -
Perhaps I should add that I always have the same setting for "end" action and "title remote" action (Stop) .
Ignore them. The disks will do what you want. (No guarantees they will play on every player.)
end of file--Adobe Encore
By koberulz in forum Authoring (DVD)Replies: 19Last Post: 18th Oct 2016, 21:21 -
Encore CS4 "End of file" error
By docfo4r in forum Authoring (DVD)Replies: 1Last Post: 31st Jul 2013, 03:57 -
Encore cuts off end of movie
By koberulz in forum Authoring (DVD)Replies: 0Last Post: 23rd Jul 2011, 00:17 -
May be End Action Question
By philwright11 in forum Authoring (DVD)Replies: 11Last Post: 29th May 2011, 15:32 -
How can I set resume mode in Adobe Encore?
By Sean_ve99 in forum Authoring (DVD)Replies: 0Last Post: 26th Sep 2007, 17:10
