Thanks for helping. Just downloaded the current version 2.5 and now I can no longer convert my ts files from my PVR to useable VOB files. SCCD2DVD seems to convert only a few of the files but not enough to use. Also had an older version of HDTV2DVD which also no longer works. It appears the ts file is being down loaded to my computer okay, via firewire using CAPDVHB.exe but the conversion is fubar.
Any ideas would be appreciated. Log attached.
svcd2dvdlog-20071223180701.txt
A search turned up this post, it's exactly the problem you have (duration isn't being read properly). Read it and follow the links.
https://forum.videohelp.com/topic280140-210.html#1603723Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
thanks for the post. This is too weird as these programs all worked fine until....?Originally Posted by Jikchung
I did follow the post you mentioned but the VideoRedo program stops responding as well and sends me the error message: File is not "mpeg program stream" Not sure what this means but file is .ts file although content is not in HD format but that shouldn't matter.
Still searching.....
svcd2dvd problem
By dvds2u in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 11:05 -
problem activating svcd2dvd
By tecker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 20th Mar 2008, 21:20 -
Is SVCD2DVD the program for my HD files?
By rimam in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 20th Mar 2008, 14:12 -
SVCD2DVD taking AGES to convert files.
By smileymyley in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 22nd Jun 2007, 14:53 -
Multiple HDTV TS files to DVD with SVCD2DVD HELP
By ndoggac in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 18th Jun 2007, 12:21
