    Dec 2005
    Asia
    I cant seem to be able to download the tryout version of Adobe premire elements.
    I did manage to do just that to Photoshop elements from the same ste at the same time...
    I get a massage that something is wrong with the internet conection [??]
    Can you guess why??
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    Your ISP may have set limits?
    USA
    It's a huge file, 2.72GB, so that may be the problem. Adobe also uses a download manager and a activeX control which your anti-malware programs may be blocking. Or as zoobie mentioned, it may be a problem with your ISP. I would also try it again at a different time as the Adoble download site might be overloaded at times.
