Receive the following error when a write is attempted with ImgBurn:
I/O Error!
DEvice: [0:0:0] ATAPI DVD A DH16A YH13 (K(ATA)
ScsiStatus: 0x02
Interpretation: Check Condition
CDB: BF 00 00 00 00 00 00 20 00 0C 00 00
Interpretation: Send DVD Structure - DVD+R DL Boundary information
Sense Area: 70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 00 00 00
Interpretation: Invalid Field in CDB
ImgBurn shows the device with the following:
ATAPI DVD A DH16AYH YH13 (ATA)
Current Profile: DVD+R DL
Disc Information:
Status: Empty
Erasable: No
Free Sectors: 4,173,824
Free Space: 8,547,991,552 bytes
Free Time: 927:32:74 (MM:SS:FF)
DVD±R DL Boundary Information:
L0 Data Zone Capacity: 2,086,912
Changeable: No
Physical Format Information (ADIP):
Disc ID: RITEK-S04-66
Book Type: DVD+R DL
Part Version: 1
Disc Size: 120mm
Maximum Read Rate: Not Specified
Number of Layers: 2
Track Path: Opposite Track Path (OTP)
Linear Density: 0.293 um/bit
Track Density: 0.74 um/track
First Physical Sector of Data Area: 196,608
Last Physical Sector of Data Area: 16,580,607
Last Physical Sector in Layer 0: 2,283,519
Physical Format Information (Last Recorded):
Book Type: DVD+R DL
Part Version: 1
Disc Size: 120mm
Number of Layers: 2
Nero 7 Recode also fails with virtually no information, it does recognise the +R DL DVD.
This drive burns single layers beautifully.
Any help appreciated,
Thanks, Hibbs.
Results 1 to 13 of 13
You're using crappy RITEK DUAL LAYER media which is why you have failed burns. Use VERBATIM DUAL LAYER media & your problems will cease.
Glad you're willing to get Verbatim. We get posts like this all the time. Basically if you use any DL media except Verbatim DVD+R DL discs, you post here asking why your burns fail.
http://www.nomorecoasters.com has info on media quality and it might be of interest to you. -
Hi,
I'm having a very similar problem to this one. Only happens when I try to burn a DL disc.
My drive is an LG GSA-4120B,
and the media is branded as Aone 8X DVD+R DL, although it shows up in DVD-Decrypter as RICOHJPN.
Are these crap disc's?
Thanks.We'll be right back after these messages from Binford! -
Yes.Originally Posted by Tool Man
Read my post again in this thread. I not only answered your question, I provided a link with data on it. -
Yes, thanks,
What I meant was, according to that link, these are Grade B discs, and so far, i've tried 4 burns and had 4 coasters.
Thats a 100% fail rate, hardly grade 'B'.
How can they get away with selling this crap, it's clearly not fit for the purpose it was made for!
Anyway, i've just ordered a pack of Verbatim's, so i'll see how that goes.We'll be right back after these messages from Binford! -
Quick update for anyone with similar problem.
I just got my pack of Verbatim disc's, and it made ZERO difference.
Disc shows as Mitsubishi Kagaku Media (MKM 003).
Still fails with the same error message. Guess some drives just don't like DL at all.We'll be right back after these messages from Binford! -
If your LG drive failed to burn VERBATIM DL MEDIA then it could be time to buy a new dvd burner. Are you using IMGBURN to burn those VERBATIM DL MEDIA? If not then that could be your problem. IMGBURN is the only known free software to burn DL media reliably.Originally Posted by Tool Man
Your problem is the WRONG burner/media combination.Originally Posted by Tool Man
Your burner is really old, you should only try burning VERBATIM DVD+R DL 2.4x rated media with it.
Can a 4x burner write to a 16x disc?
By bobarnett in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Sep 2008, 16:47 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 06:49 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 13:58 -
DVD burner doesn't write anymore
By mr-scarface in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Aug 2007, 23:18 -
Help with Memorex Internal DVD Burner
By Gdfthr337 in forum DVD & Blu-ray WritersReplies: 2Last Post: 15th May 2007, 13:08
(ATA)
