This is more or less a continuation of a previous topic on DVDshrink:
https://forum.videohelp.com/topic342844.html
But, since it involves DVDfab exclusively, I decided it best to separate the two. Suffice it to say I've decided to buy DVDfab Platinum. And using the shrinkage functions in the demo version, I'm pretty impressed in how it does what it does. But I'm still left with a question for those in the know.
I have a relatively new version of Nero installed on my system. But the only time I use it is to burn CDs. To burn DVDs, I used to use an ISOburn via DVDdecrypter. But to create the ISO file I needed to burn, I'd previously used DVDshrink ... which sadly, stopped working on my system.
The question. Does DVDfab Platinum use Nero conventions to burn a DVD ... or does it have its own burning conventions? Sometimes when using Nero, I'd get disk errors that an ISOburn via DVDdecrypter didn't get. And I'm wondering if anyone has tested disks burned with DVDfab to see if they're prone to the same disk errors as Nero?
If so, I'd like to find out if there's any utility out there that can do just one thing ... read the DVD files on my computer and convert them into an ISO file ... which I can later burn with DVDdecrypter.
Regards,
J. Alec West
Hi Alec West, Fab Platinum uses VSO's burning engine,however if you have Nero installed you can choose to burn with that..
Also If you want an iso use the clone mode and create one to HDD,for later burning...." Who needs Google, my wife knows everything" -
DVDFab Platinum will do a full rip or compress a dvd9 to a dvd5.
It will do it to either an ISO or to a VIDEO_TS folder.
And what t0nee1 said, but can save to an ISO in "full disc" "Main Movie", ect. it does not have to be just in "clone" mode.
Yeah, ImgBurn, if you don't just use DVDFab Platinum to save to an ISO to begin with.....Originally Posted by AlecWest
And burn with either ImgBurn or DVD Decrypter ect.
DVDFab Platinum is what i use most of the time to rip or do other things that DVD Shrink will not do.
DVDFAB Gold $39.99
DVDFab Platinum $49.99
http://www.dvdfab.com/fab-compare.htm -
I just noticed that today (grin). So, I can still use DVDdecrypter to do the burning. I decided to buy DVDfab Platinum the other day. I think it was, overall, the wise decision ... and know I'm definitely going to enjoy the PathPlayer feature. Versatile piece of software.Originally Posted by Noahtuck
Regards,
J. Alec West
Yep.
If you save the final dvd to an ISO you could pretty much burn it with anything that burns
When i use it that's what i do, save it to an ISO and burn with Imgburn.
And yeah, it's a nice piece of work for only $50.00 considering what it all does and is always updated.
It does burn itself either by using the built in VSO burning engine, or it will use nero if you have it installed.
I wonder why they don't set it up to use Imgburn also ? or have a feature set up so if you do have Imgburn installed you can browse for it and add it to the autoburn function.....
Maybe we should all e-mail him and have him include it in future updates/releases of the program 8) -
I used to use IMGburn a while back ... but switched to DVDdecrypter. IMGburn, for some reason, gave me errors a lot (like my older Nero did). DVDdecrypter has never failed to burn an ISO (no kidding) to a disk.
Regards,
J. Alec West
Question about possible benefits of old versions of DVDFab Platinum
By jimdagys in forum DVD RippingReplies: 2Last Post: 24th Mar 2012, 06:39 -
DVDFab 5, Platinum Question
By Ric2L in forum DVD RippingReplies: 3Last Post: 18th Jan 2009, 17:19 -
DVDfab Platinum
By jason in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2008, 11:05 -
Question on DVDFAB PLATINUM 4
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2008, 20:43 -
DVDFab Platinum
By bigdogdadog in forum Newbie / General discussionsReplies: 9Last Post: 3rd Nov 2007, 15:06
