Hi. Right. Ive backed up project dvd through DVDShrink with no compression. Ive import said dvd files into DVDRemake and hide the bits i dont want. The exported. When i tried to load up files into DVDShrink it says somethings wrong with Video TS. Any tips on wot is wrong?
Any advice would be greatfully received.
Cheers.
Ripped movie with DVDShrink then again with DVDFAB. Hid unwanted trailers etc. with DVDReMake and exported. Loaded up into DVDShrink to shrink to 4GB and take out unwanted audio. Same result with both goes. Invalid data in VIDEO_TS.Vob. I've tried a few different movies and got the same thing.
Can any one help???? -
What version of remake are you using? You can also remove the audio you don't want from inside remake. I would recommend maybe uninstalling shrink then re-installing it. I can't think of why this his happening to you, I've done this same procedure many times and all outputs from remake have worked fine? Are you sure your using rewmake correctly and not taking out a necessary part when editing?
What We Do In Life, Echoes In Eternity.... -
I'm using DVDReMakePro 3.5.3.0 and DVDShrink 3.2. Uninstalled and reinstalled shrink and same result. I followed a guide. Only hide trailers cuz they're spanish and a game. I am new to this so maybe i'm doing something wrong. It's driving me nuts!!!!!!!!!!!!!!!
I've had my own issues with DVDRemake Pro. Nero and such didn't like the files it made either. I think ImgBurn ended up setting things right in the end.
CUDA don't work, why?
By lovelylisa in forum Video ConversionReplies: 38Last Post: 24th Jun 2011, 16:19 -
BD Sup to srt and why they don't work all that weLL.
By cal_tony in forum SubtitleReplies: 2Last Post: 4th May 2011, 09:17 -
Videos don't work anymore
By SINZAR in forum Software PlayingReplies: 5Last Post: 14th Mar 2008, 12:46 -
USB Devices don't work!!
By peomp in forum ComputerReplies: 6Last Post: 5th Jun 2007, 13:12 -
Dvd's don't work after a while.
By FreeDiver in forum DVD & Blu-ray WritersReplies: 15Last Post: 11th May 2007, 00:46
