Looking for a program that will transcode my .avi files onto a DVD, however it must have the following support
-allow me to add subtitles in the form of .srt
-allow me to 'compress' the video (to Long Play, Super Long Play) etc if the video is (for example) 3hours long
-allow me make a sub menu where I can select chapters (or have this as main menu)
I tried DVDflick but they don't have a menu so you can't choose your chapters.
I tried Avi2DVD but they always ask me for an audio source when I only have the .avi and .srt
I tried neroVision but they do not have support for .srt (they have the compression I'm talking about btw)
I tried Convertxtodvd, but it seems like you can't do a scene selection. (like DVDflick except I have a menu without a chapter selection sub menu)
So any good ones out there?
Results 1 to 15 of 15
Try tmpengc dvd author 3 - that now includes avi conversion and has very good menu support. HOWEVER I can't gurantee it has subtitle support - I know tda 1 and 2 lacked that feature - or I never knew how to use it if it was buried in a submenu.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
sounds good! I'll check it out right now and let you guys know how it went. Thanks!
Okay I just tried tmpengc dvd author 3 with divX authoring but when I go to add my .avi files it gives me an error message saying only the audio can get added and not the video.
Do I need divX codec installed for this to work?
Any other programs out there? -
GUIforDvdauthor does not recognize any of my .avi files
only displays the .mpg and .mp4 (maybe .wmv but I dont have that format) -
Avi2Dvd is picky with names/paths. The easiest way is to put your AVI in your C: drive and give it a one word name (C:\MyMovie.avi).Originally Posted by emailissent
With Convertxtodvd make sure you have the viewer enabled, you can use the slider to find the portion of the video you want and set chapter stops. -
Okay I'll try again with Avi2Dvd
but with ConvertxtoDVD I mean, when everything is already done, I want a chapter submenu where I can go and select a certain chapter instead of scrolling all the way through -
Seems the new ConvertX will be addressing many menu needs.Originally Posted by emailissent
http://www.vso-software.fr/screenshot/convertX3-news/
What program to make menued DVD using multiple flv files
By rdfarr in forum Authoring (DVD)Replies: 4Last Post: 8th Mar 2011, 07:18 -
Help. What program to use to make avi files play on dvd player?
By xxxThiefxxx in forum Newbie / General discussionsReplies: 13Last Post: 30th Mar 2010, 17:09 -
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 23:48 -
What program to use to make a dvd?
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2007, 01:22 -
Looking for a presentations program to make dvd menus
By faramith in forum ComputerReplies: 0Last Post: 1st Jul 2007, 10:00
