I used TMPGEnc Xpress 4.0 and tne XDVD profile to convert several video files into XDVD mpg files that totals to around 4GB for the filesize. However, when trying to create a DVD in DVD author with them, the filesize balloons to somewhere a little over 9GB. I don't know why it does this, considering the original file sizes of the MPGs are only 4GB. I am tempted to just drag the MPG files into Nero and hope my DVD player is smart enough to just play them straight off without needing to convert to VOB files.
That's why I keep my copy of TMPGEnc DVD Author 1.5. It will create a fine XDVD with no problems.
I would suggest you place this question to TMGEnc developers as if one of their tools provides the profile, the other one should handle it. -
I use TMPGEnc DVD Author 1.6. The software produces DVD of almost the same size of the files I give it. For example, if I want to author 4 GB of video materials (vob or mpeg files), the software will author for me approximately 4 GB of DVD.
What is an XDVD, anyway? Is it something better than the regular DVD? -
I am using the latest one I think. TMPGEnc DVD Author 3. I've tried to just ignore the warning, but it takes like 3-4+ hours to create a DVD now that used to only take 20 minutes. It is probably doing some kind of transcoding, I'm not sure. I've tried using a demo of the old nero vision express and it has the same problem, albeit the filesize comes out to be more like 6GB than 9GB.
Something that isn't really a DVD. Some think they can "improve" on the DVD std by breaking it, and can't understand why their apps insist on correcting the errors.Originally Posted by moviebuff2
/Mats -
TMPGEnc DVD Author 3 will re-encode the file to be compliant with the DVD standard. If you don't want compliant, as in a XDVD, use a different authoring program. But good luck on playback with many set top DVD players.
Why not stick to a standard format DVD and avoid all these problems?
A 'XDVD' would be defined as anything that doesn't comply with the DVD structure, format and specifications.
See some of them here: https://www.videohelp.com/dvd -
Oh...at a moment I thought XDVD designated DVD containing......,you know what!Originally Posted by mats.hogberg
I agree with redwudz. If XDVD does not improve anything and cause that much trouble, why not simplify your life and stick to the standard normal DVD.
I'm for everything that is normal.
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 19:48 -
TMPGenc DVD Author 3 Maximum Size
By Shadowofthedarkgod in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 18:59 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 10:00
