  1. GUYS
    I am newbie to FLAC file format I tried to play FLAC file format but I was not able to play How can I convert these songs in other wma format?
    thanks in advance
    Apr 2002
    In front of my monitor
    Rather than converting them, why not download the OGG codecs and play them as-is?
    I don't remember exactly where to find them but Google should come up with them pretty quick.
  3. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Official FLAC application including WinAmp plugin for playback:
    http://downloads.sourceforge.net/flac/flac-1.2.1b.exe
    Frontend (encode/decode to wav GUI) for FLAC:
    http://members.home.nl/w.speek/download/FLAC_frontend.zip
    Other FLAC downloads:
    http://flac.sourceforge.net/download.html
    http://www.rarewares.org/lossless.php
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Flac is a LOSSLESS Compression for audio.
    Use this to extract the WAV file,
    Trader's Little Helper
    Then you can convert the wav file to anything you need, but once converted to a LOSSY format the original LOSSLOESS version can never be retrieved unless you keep the original Flac or Wav files.
    A little search would have netted you at least a couple of threads on this subject 8)
    https://forum.videohelp.com/topic334109.html#1734181
    https://forum.videohelp.com/topic336481.html?highlight=flac
