I have some broadcast quality videos that were created on FCP, on Apples of course, and I have compressed them using H.264 with Handbrake. The result looks pretty good but the data rate is too high for the PCs that a lot of my colleagues use at work, so it doesn't play smoothly. Can anybody suggest what is the best way to get them into a format with a lower data rate, and also in a format that will play on WMP? I need WMP because a lot of people at work don't have Quicktime on their machines. I have tried Quicktime Pro but when I export it as an MP4 file, the quality drops dramatically. Basically the new files can't handle any significant camera movement. If anybody has seen any good how-to manuals explaining how to set each of the variables in one of these conversion programmes, I would love a link to it as well....
TIA,
Jeff
Use Quicktime Pro to export as a DV format AVI file.
Any PC from the last 5 years or more really shouldn't have a problem playing it and it will be exactly the same quality as your original.
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Suggestions to convert YouTube .mp4 to a format that plays on Windows Mobile (WMP)
By AshleyQuick in forum Video ConversionReplies: 0Last Post: 30th Jan 2010, 13:43 -
Help convert avi to WD HD Player -Playable format
By anbures in forum Video ConversionReplies: 1Last Post: 7th Nov 2009, 06:27 -
massive trubb with FCP output
By blunderbus in forum MacReplies: 0Last Post: 20th Feb 2009, 09:51 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
