I recorded some music sessions of a friend and while the video isn't the greatest and doesn't seem worth messing with I would really like to put the audio in mp3. I have no idea where to start.
Regards
Jensen
What about realtime recording from the audio output of the camcorder? If you haven't already transfered the video to the pc then simply play the video in the player but hook up the audio output into the audio input on your computer. then use any software recording sutie that will record from the input and you can record to wav or mp3.
If you already have the full video and audio on your computer than try aedipuss's suggestion. Good luck.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I still have the mini-dv and the capture on the comp. I was able to use yodas idea, thanks. I used the a/v cables and hooked up the adapter for the computer. I love adapters so I have an assortment of them, I just went rca to the comp and recorded in my ringtone maker. Thanks all
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850 -
I know you've got it sorted, but you could also try opening the DV AVI in something like Audacity (I think it takes AVI's) and then save the audio out to MP3.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
You could also open in Virtualdub and save the wav then convert to mp3.
Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited."
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
Mini-DV audio cutting out
By sonicdeth in forum Video ConversionReplies: 2Last Post: 7th May 2008, 19:03 -
Audio on JVC mini tapes
By josel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Jul 2007, 20:25
