first, i tried to do it with Boilsoft joiner (as i always do) but i'm getting this alert:
so i tried to do it with VirtualDub and again - no success...
this time, i'm gettin this alert:
what?!![]()
what exactly the problem?
how can i solve it and join this two parts together?
any help appreciated!
Thanks in advanced!
That VD error has the reason: The audio streams are different sample rates. You would need to re-encode one or the other so they both match exactly, then they should join.
BTW, if you are joining them to encode to DVD, you can also just encode each part separately, then let your authoring program do the 'joining'. Then you don't have to worry about them matching. -
Thanks man!!!
it worked!
i encoded the files' audio and joined the two together!
no, just to play it on my CD...Originally Posted by redwudz
Join AVI file
By czgirb in forum Video ConversionReplies: 3Last Post: 19th Jun 2011, 21:53 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 12:49 -
Join AVI files together ?
By terryfox in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 22:56 -
Simplest way to join 15 avi's into 1
By macbuz in forum MacReplies: 3Last Post: 20th Jan 2009, 16:06 -
How do i join 2 .avi clips?
By vandaLo in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 20:52
