I can't seen to figure out how to convert this avi to mpg using TMPGEnc so that it would appear correctly on my tv. It's a widescreen avi movie and pretty good quality, but it appears really mixed up and stuff on my television. the stats or whatever for it are
MPEG-1 640x360 29.97fps CBR 1150kbps, Layer-2 48000Hz 192kbps
that's what appears on TMPGEnc, I was thinking it was the aspect ratios that i had to adjust to properly encode but I can't seem to figure it out.
You should open the avi in VirtualDub and view the file properties.
As far as I can see, the framesize is 640x360 and the audio samplerate is 48kHz.
In TMPG go to setting > advanced > source aspect ratio 1:1, video arrange method: full screen [keep aspect ratio]
Even better select video arrange method center[custom size] and type
320x164 (NTSC) or 320x196 (PAL)
At the video tab set aspect ratio 4:3.
According to the VCD standard you have to downsample the audio to 44,1 kHz. (audio tab)
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
Widescreen aspect problem converting avi to dvd
By spiritgumm in forum Video ConversionReplies: 8Last Post: 10th Apr 2010, 14:14 -
Convert avi to 16:9 widescreen
By sknoxxx in forum MacReplies: 4Last Post: 28th Aug 2009, 21:50 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 02:49 -
AVI widescreen fix?
By robburne in forum Video ConversionReplies: 5Last Post: 23rd May 2008, 14:29
