    Aug 2007
    Hi i'd like to make a ts. folder so i can burn my avi to dvd and have it play on lap top and on a tv -
    i am usuing ffmpegx
    in the to section there are lots of options of formats, though none saying ts.
    there are 3 dvd format options
    dvdlo
    dvdmpeg2enc
    dvdffmpeg
    there is also mpeg ts - which i ve already tried and ended up witha file with a vlc symbol on it, so I guess that no good.
    any advice - its for a christmas present and yep! i left it right to the last minute
    thanks all
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    dvdlo = DVD preset for reduced (low) resolution
    dvdmpeg2enc = DVD preset using the mpeg2enc engine
    dvdffmpeg = DVD preset using the ffmpeg engine
    mpeg ts = transport stream (like broadcast), not for DVD.
    Without knowing more about the AVI, I would suggest using the dvdmpeg2enc preset as best allround choice.
    Aug 2007
    thanks case... happy christmas to you.
