I burnt a DVD with Adobe Encore, put it in my DVD player, and nothing happened for a few minutes. After a while, the main video started playing. I'd set it up so a short clip played, then went to the main menu. Both these steps were skipped for a five minute wait period before the DVD played.
I then created an ISO. It functioned perfectly in PowerDVD when mounted with PowerISO. I burnt the ISO with Copy2DVD, but it had exactly the same problem...a few minutes of nothing, and then it skipped the pre-menu clip and the menu, to go straight to the main feature.
What's going on, and how do I fix it?
Anyone?
Hardware? Software? User? I'd really like to get this fixed. -
The DVD didn't work on the computer, it had the same problem as on my player. The mounted ISO worked on the computer.
So high possibility problem with DVD-R/DVD+R media or with DVD writer.
Try write different DVD media. -
Are you burning Single or Double Layer?
How did you create the ISO Image?
DVD quality from Encore CS5.1
By surffx in forum Authoring (DVD)Replies: 6Last Post: 21st Nov 2011, 04:51 -
Trouble With Improperly Muxed MKV
By Startropic1 in forum Video ConversionReplies: 1Last Post: 16th Jul 2011, 18:41 -
Burning DVD Encore 2.0
By Usagi Tsukino in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2009, 13:10 -
Fixing an improperly mastered DVD
By Cronos in forum Video ConversionReplies: 14Last Post: 26th Oct 2008, 23:53 -
DVD duration on Encore
By bltprf in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 09:23
