I have some mpeg-1 files that I made at 704x480, 2520 bitrate. I used them for my xVCD and they played great on my Pioneer DVD player. But xVCDs don't work so well on all DVD players. So now I want to convert those hi-res mpeg-1 files to a VCD-compliant 352x240, 1150 bit rate.
But when I use the hi-res mpeg-1 as the source file, and render it to the 352-240 file, the audio gets out of sync but a half a second. Also, there is some sound blips that appear from time to time.
Is there a better way to convert an MPEG-1 to a lower quality MPEG-1 than simply using TMPEGenc's standard (avi to mpeg) converter tool? :(
In TMPGENC, under Option/Environmental Settings, bump up the priority of the DirectShow filters to something like 5, this should take care of your synch problems.
If this still does not help, use VDUB to extract the audio first, and encode using the resulting WAV file as audio source.
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 14:43 -
How to convert 704x480 to 720x480 without re-ecnode?
By rogalewski in forum Video ConversionReplies: 18Last Post: 27th Aug 2009, 22:47 -
Help. Convert menu sublayer from 720x576 to 720x480 (PAL to NTSC)
By danfisherman in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2009, 12:56 -
How to convert 640x480 to 720x480 ?
By webstar in forum MacReplies: 3Last Post: 8th Jan 2008, 10:44 -
What should I do w/ Video OpenDivX4 720x480 24.975 PAL/NTSC? fix or convert
By JoeBolden in forum Video ConversionReplies: 1Last Post: 15th Dec 2007, 23:12
