Here's the AGK message....
[12/23/2007 10:43:41 PM] Format: AVI
[12/23/2007 10:43:41 PM] Target size: 896Mb
[12/23/2007 10:43:41 PM] Audio 1 settings: Auto
[12/23/2007 10:43:41 PM] Started encoding.
[12/23/2007 10:43:41 PM] Source resolution: 640x400
[12/23/2007 10:43:41 PM] Source fps: 25
[12/23/2007 10:43:41 PM] Analyzing source.
[12/23/2007 11:29:47 PM] Source has percentage of interlacing in motion areas: 0.00
[12/23/2007 11:29:47 PM] Source is considered to be progressive.
[12/23/2007 11:29:47 PM] Output will contain 120000 frames
[12/23/2007 11:29:47 PM] Demuxing audio.
EXCEPTION: Unsupported audio type.
And here's what GSpot says about the failing file (file1) and another file (file2) that ran just fine in AGK....
File Name .............: file1.avi
File Size (in bytes) ..: 734,015,488 bytes
Runtime (# of frames) .: 1:20:01 (120000 frames)
Video Codec ...........: XviD ISO MPEG-4
Frame Size ............: 640x400 [=1.600]
FPS ...................: 25.000
Video Bitrate .........: 1097 kb/s
Bits per Pixel ........: 0.171 bpp
B-VOP, N-VOP, QPel, GMC ......: [B-VOP]...[]...[]...[]
Audio Codec ...........: 0x0055 MPEG-1 Layer 3
Sample Rate ...........: 48000 Hz
Audio bitrate .........: 113 kb/s [2 channel(s)] VBR audio
Interleave ............: 40 ms
No. of audio streams ..: 1
File Name .............: file2.avi
File Size (in bytes) ..: 729,135,104 bytes
Runtime (# of frames) .: 1:54:19 (171454 frames)
Frame Size ............: 624x368 [=1.696]
Video Bitrate .........: 724 kb/s
Bits per Pixel ........: 0.126 bpp
Any clues as to why file1 gives the error message???
	The file itself might just be jacked. Run it through AVI_Gain_Regular.bat https://forum.videohelp.com/topic314909.html
 That'll hopefully fix the MP3 problem.
	Thanks for trying to help.... I ran normal on the file, started AGK on the result... and VirtualDub crashed with an out of bounds error - GRRRRR  . .
  AutoGK: Unsupported audiotype! Here's what i tried.By Moonwalker1982 in forum Video ConversionReplies: 1Last Post: 14th Feb 2009, 06:34
  AutoGK Error MessageBy WuPhilly in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2008, 19:12
  "Unsupported audio rate in file" Message in Premiere Pro CS3By JustinBaker in forum AudioReplies: 2Last Post: 24th Mar 2008, 00:27
  AutoGK Error - Unsupported audio typeBy bjblackmore in forum DVD RippingReplies: 7Last Post: 13th Jun 2007, 20:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
