The border is only added to the top and bottom and not the sides, right? Could you change it so the border is added all around the picture from all four sides? I watch fansubbed anime and the subtitles don't cut off the bottom of the screen cuz of the border but sometimes the subs will take up the entire width of the screen and the first and last letter of a sentence will get cut off. Pretty Please could you do this? You program is perfect except for this. Only other improvement I can think of is I wish the menu this program creates would like similar to vso's convertxtodvd. their program sucks compared to your except for the menu. it 's black background with each video files title listed and numbered. you can pick which you want to play by highlighting it with your dvd remote.
As for the overscan, I don't have access to the program right now but I'll get back to you when I do. Hopefully someone else might address it before then.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
OK, I have checked and overscan is properly applied all the way around the image, not just top and bottom as you said(that really wouldn't have made much sense, would it?).
I think the problem is with your sub files and the positioning specified in them. A subtitle editor should allow you to work on size and positioning of the ext.Dwight
- Herm Albright
Similar issue, however mine are permanent embedded in Avi's (xvid coded)
Have you tried adjusting for the overscan area in video settings?
Dwight
- Herm Albright
Widescreen DVD menu overscan problem (only on older equipment)
By Grunberg in forum Authoring (DVD)Replies: 7Last Post: 15th May 2011, 07:39 -
IfoAR2WS Feature Request
By TheArtfulDodger in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 12:36 -
Overscan border
By milway in forum Authoring (DVD)Replies: 5Last Post: 1st Jul 2008, 17:03 -
[Feature Request] Please add batch video conversion option!
By Panarchy in forum ffmpegX general discussionReplies: 0Last Post: 20th May 2008, 07:13 -
Desperately Looking for a DVD Player with Overscan Compensation Feature
By Cottontree in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th May 2007, 16:53
