Okay, it seems lots of people are putting a movie disc into their PC's, the drive spins a lot, and then nothing happens. According to XP's device manager there isn't a disc in the drive. Take the disc out and put it in a stand alone player and it fires right up with no problems.
Is it some kind of DRM that us noobs don't know about? Do we need to switch operating systems? Seriously what the hell, I have a brand new factory disc of the Simpson's Movie that I payed $19.99 for at Best Buy this afternoon and I can't watch it because I don't have a TV and it won't play in VLC because the system doesn't even recognize that I put a disc in the drive. It fired right up in my Uncle's old JVC player, not modded or anything.
Results 1 to 11 of 11
This may be a dumb question....but does your computer have a dvd drive?????
Not just cd??? -
Lite-on 20x SATA DVD-RW running on a asus A8R32-MVP with an Opty 175 at 2.61ghz(slight overclock). Graphics card is a 2900XT 1gb from sapphire. Drive plays othe DVD's without a hitch.
Put certain disc in, loud noises like drive spinning, then nothing. According to MYComputer there is no disc in the drive. Take disc out, put in DVD player in living room, starts right up. -
Jimbo thank you for replying, but let me rephrase.
I have a large DVD collection, I have for years used Media Player Classic and now VLC to play my factory dvds on my PC. VLC can't play this one because WINDOWS won't recognize that it is even there. But the five year old JVC hooked to the TV sees it just fine. -
I have had it happen a few times with cheaper discs where a burned dvd (data or video) has choked in my LG (PC) with the same symptoms you describe yet the older NEC (PC) writer and the household players play just fine. There are calibration errors caused when the disc is originally burned that some PC writers don't seem to overcome. Standalone players are more forgiving.
You could try cleaning it just in case. -
Just tried my new Firefly 4-disc set out that I also bought at Best Buy today. Disc 2&3 also won't play, same symptoms, but they both run on my brothers Dell. Think I'm in trouble.
SCDVD said it all.
-------- original message below ----------
Midzuki had written:
Maybe the lens of your DVD-drive is dirty.
Or the entire device is dying
Now watching the Simpson's Movie on an old IDE Samsung DVD PLAYER. I think it's a 2x, and it's playing the movie fine. Bad drive.
Put Blu Ray disc in regular DVD player???
By Tech Challenged in forum Newbie / General discussionsReplies: 18Last Post: 20th Feb 2009, 10:09 -
Will a blu ray disk play on regular dvd player in 480 lines of resolution?
By donfm in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2009, 06:00 -
Will my regular DVD player play a "blu-ray to DVD " disc ?
By htp367 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Oct 2008, 12:28 -
DVD Does not Play in Drve, But plays fine in Player
By HellSaber in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Feb 2008, 16:13
