  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi,
    Anyone facing problem with WPA/WPA2 security access with Win Vista. I am using Vista Home Premium and Intel wireless card. Just couldn't get it to work and have to revert to WEP.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Worked fine for me using a Linksys router. Vista setup the connection, I only had to choose the wireless network and supply the access code.
    Google is your Friend
  3. I've had trouble with a Broadcom card and Vista not auto-connection to hidden networks but nothing with WPA so far.
  4. I had exactly the same problem with a computer running Vista - WPA wouldn't work. Other Vista machines were OK.
    Unfortunately, another computer with XP refused to behave with WEP!
    So I can't use either, therefore I have an allowed MAC address list plus I live on an old farm and the chances of anyone trying to cadge a ride is very remote.
  5. Member pchan's Avatar
    Mar 2003
    Singapore
    Thanks for the sharing. I ended up with WEP and MAC address.
