Hi! I have been trying to figure out how to get my SE W810i to play MP4 videos at the full screen size. The screen is 176x220, but it only allows QCIF videos at 176x144. Trying any other resolution will either cause the phone to return an error or treat the file as if it is audio and play only that. I have done mucho searching in all the cell phone forums (Howard Forums, ESATO, SE-ENSE, etc) with no luck. Everyone seems to think it's impossible. I am very surprised that no one has come up with a patch or hack, since this model has been customized like crazy by the community. Anyway, the walkman player will rotate and stretch a 176x144 video to full screen, but of course, it looks like crap. I am assuming that if the phone can do this, it has the ability to play a 220x176 video landscaped.
My experiment is to try to trick the phone into thinking it has a 176x144, when it is really being presented with a 220x176 video, encoded at 90 degrees (effectively 176x220). I am using The Matrix, ripped from DVD to XVID AVI and AAC MP4A files. I used a program called ABC AVI Tag Editor to edit the AVI header to show 176x144. I checked with GSpot after, and it shows it is 176x144. The only problem is, when I mux the modified video and audio into an MP4 (with MeGUI), the final MP4 shows that it is 176x220. Does anyone know how I can make the outputted MP4 show a 176x144 frame size in the header? I can't seem to find any info or program on editing an MP4 header.
Any help would be greatly appreciated. Thanks!
Closed Thread
Please don't cross post. Bump your first topic instead, https://forum.videohelp.com/topic342616.html .
151MB mp4 file - with header problem?
By supermaster in forum RestorationReplies: 7Last Post: 6th Jan 2012, 09:52 -
Crop VP6 video using frame header?
By KeyMs92 in forum EditingReplies: 8Last Post: 5th Nov 2011, 18:13 -
MP4 never closed, missing header?
By ETM in forum Capturing and VCRReplies: 5Last Post: 25th Feb 2011, 16:40 -
Edit MP4 frame size metadata
By tb582 in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 23:13 -
How to edit MP4 header frame size?
By Darney76 in forum Portable VideoReplies: 4Last Post: 7th Jan 2008, 22:58
