i have philips dvp3166.. an avi file played as a very small image on my tv.. thinking that it had to do something with the image size setting, i changed it to 672*288, the setting of another video
which had played ok on my tv.. it didnt work too.can any1 help me?
well too small means that not all the tv screen area is utilised for displaying the image..
it is surrounded on the 4 sides by black area.. the picture is in the middle..'the image doesnt fit the screen' might be a good description -
672x288 isn't going to fill it in any event, even a widescreen TV set. It should play with black above and below.
I'll assume you have a widescreen TV set. Make sure your player is set up to output for widescreen TV sets (aka 16:9). -
no,its a normal tv.. i will try that.. anything which i should differently in the encoding section???
its an avi file,converted from mkv -
thanx man..it worked..the setting in my player was 'widescreen'..
changed it to 4:3 mode... it worked...grttt thanx for helping me out on that stupid
question -
There is no complete standard for Divx/Xvid playback by standalone players. I am running two currently, and both handle the same files differently. The Pioneer correctly switches between widescreen and fullscreen files without a problem, and sends appropriate flags through to the TV (a 4:3 with widescreen switching). The LG, on the other hand, sends everything through as 16:9 if it is set to 16:9, even if the source is obviously not. In which case I get the same problem as you have. I find that for 4:3 material I have to manually change the setting on the LG or I get window boxing. Obviously the Philips has the same poor quality handling as the LG models.
Read my blog here.
cant exactly say its poor quality handling... there is a video setup option,and i have changed the option there...so now it automatically displays any file according to its resolution.. i dont hav to do it manually everytime..LG 2 might hav such an option
Exporting smaller files from small avi originals?
By loiseye in forum EditingReplies: 4Last Post: 17th Nov 2009, 17:38 -
vdub virtualdub can I combine several small avi files into one
By case310350 in forum EditingReplies: 2Last Post: 5th Jan 2009, 02:23 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
AVI files are too small when copied to a DVD
By lmcnlcy in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2008, 00:44 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 17:31
