Okay I allmost have it perfect now:
Card:
Pinnacle PCTV Pro
Capture :
Size:352x288 (PAL) and 24 bit RGB
Codec: PICVideo (at 18)
TMPGEnc :
Template: VideoCD(PAL)
Motion search precision: High Quality (Very slow)
No Filters
Well I know it can get better. Give me a reply![]()
I'm very new to capturing, but if you're going to watch vcd
on a tv try to use a "sharping" filter as the picture sometimes seems to "soft" on the tv. Also capture in a higer resolution and the resize down would look better (I think).
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
