Hi All been pulling hair out trying to make a photoslideshow using adobe premiere Pro, well acually its Encore im having the problem with??????????
I Have edited the photos on the timeline in pro with lots of zooming in and out on each photograph and it plays fine, now then when I export the time line using media encoder as an meg2 file(settings, Pal, none fields, CBR 9mbs) and load the mpeg into encore and burns its fine................
if I export using the mpeg2DVD setting in pro it produces an mpeg and separate audio file, when I load these into encore and author to disc encore stops half way with an error message and wont continue.
After hours of pi**ing about I have sussed out that if I remove the zooming and panning etc from the pics on the timeline this mpeg2dvd file authers okay using encore,strange I say?????????
Can anyone answer why this is??????????? surley panning in on stills is fine???
Also shall I just use the meg2 option instead of mpeg2dvd?????, whats the difference?????
Cheers any help would be wonderful,
Merry Xmas All.....
Results 1 to 1 of 1
Premiere cs5 is crashing during the editing (is closed by someself)
By vladinar in forum EditingReplies: 2Last Post: 7th Feb 2011, 06:41 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Adobe After Effects 7.0 Pro Crashing Problem!
By SciFiGeek17 in forum EditingReplies: 1Last Post: 3rd Jan 2010, 19:01 -
Adobe Premiere Elements 7 keeps crashing
By NP11073 in forum EditingReplies: 7Last Post: 22nd Oct 2008, 02:23 -
Premiere Elements Keeps Crashing
By DrawnIntoIt88 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2008, 15:32
