  1. Hello.
    I have a 4 Gbytes AVI file captured using FlaskMPEG tool from a DVD. The "split file" option inside of Flask doesn't work with Windows XP (it worked with Windows ME but now I don't know why it is not) so, the only option I have is to generate a very big AVI file that later I cannot use with any other software because it is too big. What can I do (or use) to spli it? I have tried many other tools like AVIedit, Ulead VideoStudio and others and no one can even open it. Any advice? Any ideas?
    Thanks.
    luisdaniel1.
    Caracas, Venezuela.
  2. Go here http://www.digital-digest.com/dvd/downloads/all_downloads.html there are some file splitting utilities that may help.
    Also when clicking the submit button if you get a white screen don't click it again. Just hit you back button and return to VCD home.
