Hi Group !
How to mux the video and audio files produced
from Pinnacle DV500 and Premiere 6 timeline with Pinnacle mpeg II output.
When i doing this with TMPGenc the program
tells me that the audio file is not avalid audio
file.
It's a Wave file.
And i do not whish to use Minerva.I do want to use
TMPGenc.
Brgds Erling Asker
erling.asker@telia.com
You'll have to convert your wav into an mp2 first.
Load only the wav into TMPG, check audio only, select your settings, then encode.
Browse through some of the help guides, and these forums for some other options, but the above will get you started.
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
Trying to mux / demux
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 12:07 -
MUX Help (newbie)
By thisisjontheman in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 08:52 -
Mux audio
By jgv115 in forum EditingReplies: 2Last Post: 18th May 2008, 01:56 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
