Can someone pls help me with a code for making my Bose Lifestyle 18 Series III into a multiregion
DVD player. It's a region 2, Europe, coded unit. Bought it this week.
Gosche
I bought mine in Singapore. It came with instructions to make it multiregion.
It says
1. Insert the DVD and press [CD DVD].
2. Wait for incompatibility message to appear.
3. Then press the following sequence of buttons [right], [up], [shuffle], [stop], [mute].
4. * Cd tray will open and close (didn't for me, did it manually).
5. Play DVD for 30 secs and then [stop].
6. Press the off button and wait for 30 secs.
That's it. It may or may not work cos mines from Singapore but its worth a shot.
cheers -
Hi Meebs,
Thanks alot. Tried it a few days ago and it works
Kind regards
GoscheGosche -
Hi,Originally Posted by meebs
I bought a lifestyle 28 from the states and bought it back to Singapore. Armed with the crack code, I hook up the system and was ready to de-code it but, after loading in my pirated Transformer bought from China, I was pleasantly surprised that it actually played with no problem at all. I tried with another dvd(from China as well), and it played like any other dvd player!!
Does Bose media centre has a kind of locking code function(like some dvd player and computer) whereby it locks the code of the last dvd disc it played or revert to the actual region it supposed to play after playing disc from other regions for a couple of times?
Thanks!
Elliot -
yes. some dvds are not encoded with region codes and they should be playable by any player, even the players that are locked to regions.Originally Posted by flyboy744
Hi, my first post. I bought a Bose AV18 recently to replace an AV28 that had a broken cd/dvd mechanism. All has been well until I did the above multi region hack - the unit will now play multi region dvd's however the picture aspect ratio doesn't fill the screen, almost like it is 14:9 rather than 16:9. I've tried system settings on the Bose unit & also on my TV, nothing allows me to get full screen.
Any suggestions would be appreciated.
Hack code for multiregion DVD Samsung MAX DX75???
By ltcdrcharisma in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Mar 2011, 17:46 -
Bose lifestyle 28/35 multi-region???
By kungura in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Oct 2010, 15:26 -
Technika DVDFAW08 Multiregion Code and XVid Compatibility Issues
By delta925 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Dec 2009, 14:40 -
Bose 1-2-3 Lifestyle 18 DVD Setting problem
By dougbr2480 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2009, 23:25 -
Multiregion code for LG DK7821P
By ieh4f in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2008, 16:11
