    Apr 2006
    I have used Mencoder to go MKV H264->AVI. Eventually, I will use CCE and AVISynth to convert to an MPEG-2 and place it on a DVD.
    For H264 Files, I am normally forced to use AllToAvi. I want to know how to use Mencoder to accomplish this task without AllToAvi.
    Here is the specs for my TEST MKV:
    For testing, I used Mencoder to re-encode to AVI and the command line is below:
    <command line>
    "C:\source\exe\mencoder\mplayer\mencoder.exe" "C:\Movies\Test\input.mkv" -aid 0 -o "C:\Movies\Test\output.avi" -ovc lavc -lavcopts vcodec=mpeg4:mbd=2:trell:v4mv:turbo -vf scale=640:427 -oac copy
    </command line>
    The question I have is I specified MPEG4 video codec in mencoder but when I looked at the specs in GSpot, the video codec of the rendered AVI file said the following:
    Why doesn't the video codec say MPEG4?
  2. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    FMP4 is mpeg 4, like Xvid is mpeg 4, as divx, h264 ....... If you wanted Xvid, define -ovc xvid, then set the correct -xvidencopts. Or use the -ffourcc setting to force the desired fourcc (DX50).
    See this for -xvidencopts http://www.mplayerhq.hu/DOCS/HTML/en/menc-feat-xvid.html#menc-feat-xvid-example-settings
    Apr 2006
    Thanks for the reply and clearing things up.
    I wanted to use lavc.
    Apr 2006
    Another mencoder question
    What does the lameopts option "mode" mean? I have seen it set to 0 and 3 but could not find what it means.
    Ex: oac -mp3lame -lameopts cbr:br=128:mode=0
    Dec 2004
    Triptonia
    mode=<0-3>
    (default: auto)
    0 stereo
    1 joint-stereo
    2 dualchannel
    3 mono
