I have a fast Athlon system,big hard drive,oodles of memory,I have a geforce 2 graphics card and a Pinnacle Studio DV PLUS(Dv capture card)with analougue out,but no analogue in!! a panasonic dv Ds 27b camcorder(dv in enabled by reg hack) - basically i need to capture of a VCR or TV with equipment i have, i have tried Filming with my camcorder directly off the screen but when footage transferrred to the PC , the white balance doesnt see write also can see horizontal lines on capture(because i suppoze im zooming in so much) anyone got this techique to work with good results?? which will mean i can transfer all my VHS movies onto my pc and make VCD's- i hope ive made myself clear and peeps know what im on about...but its a very good concept if i can get it to work, sound isnt a prob as i can plug that straight into the pc or camcorder to capture-I have manual settings on camcorder so i can film at 1/5000 of a sec if i wanted to and also manual whitebalance...plz help with any info...or has anyone tried anything similar!!!
Results 1 to 9 of 9
Hi,
Try to buy a PCTV, it costs a tenth (US$50,00 or less) of the DV Plus and can get you infinite superior results than the technique you are trying to apply. -
If you have a analouge in on you're camera you should be able to connect vcr to camera(analouge) and then camera to PC(dv). This way the camera works as a A/D converter(Analouge to Digital). I know you can do this with some of Sony's cameras.
Thats the prob!!! i havnt got analogue in....i need a way around it i.e filming directly off the screen!! cn u achieve good results??
If you have already spent thousands what diff does it make if you spen $50 more?
Lol,,,,,I can afford 50 dollars more....i need to do somet with what ive got...if only i had bought a camcorder with analougue In...
You only need a $85 PV231 card to make VCD's of good quality. Use almost any PC with an open PCI slot. http://steve.kittelsen.com/pv231
You are never going to get good results by taking a video of your TV screen. Forget it.
You need to purchase a capture card with Analogue inputs OR, capture from TV using the DV in feature, using the DV camera as a pass through which is connected to your computer via a firewire cable.TOMMO -
Originally Posted by JohnnyZee99
This can't possibly work well!
Hundreds of thousands may lose Internet in July
By TreeTops in forum Off topicReplies: 4Last Post: 21st Apr 2012, 22:49 -
Equipment & Software Required To Host And Stream Live Video To Web
By wet bimbette in forum Video Streaming DownloadingReplies: 0Last Post: 26th Nov 2011, 05:18 -
PCIe 1x slot, TV with analogue Capture required
By max_e_mum in forum Capturing and VCRReplies: 0Last Post: 10th Oct 2009, 00:26 -
Trying To Capture NTSC VHS Video With UK Equipment
By pbar in forum Capturing and VCRReplies: 37Last Post: 21st Jul 2009, 10:59 -
Equipment advice needed for VHS to PC capture.
By kajinofe in forum Capturing and VCRReplies: 23Last Post: 19th Nov 2007, 18:45
