I demuxed a DVD with DGIndex and again wound up with a d2v file that references the VOB files and not the m2v file it created so I opened the m2v file and hit save project to get another d2v with the correct file referenced in it. The thing that I noticed is that while the timestamp appeared during the demuxing, it did not appear during the creation of the new project file the second time.
I am wondering if this might cause any problems during encoding (once in a while I've had a source mismatch during the second encoding pass) or if its irrelevant that I do not "see" the timestamp during the creation of a project file or if I have to use Restream or something else to reset the timecodes?
I've done that before (make a D2V of a DGIndex demuxed M2V) and never had a problem.
Another solution (the one I usually use) is to demux using PGCDemux and then make the D2V Project file from the M2V that PGCDemux hands you. I'm assuming that however you do it you're frameserving using AviSynth. I've had no experience doing it any other way and don't know of any possible problems you might encounter.
DGIndex creates .ac3 file double in length (timewise) of video
By karpodiem in forum Video ConversionReplies: 1Last Post: 20th Jul 2011, 16:51 -
Renaming AVCHD file using timestamp
By cheerful in forum Newbie / General discussionsReplies: 3Last Post: 9th Jun 2011, 09:10 -
Duration & Last Timestamp Conflict On .Flv File
By ThreatTV in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 08:04 -
Cannot open file for audio demux output in DGindex
By andy_blah in forum DVD RippingReplies: 5Last Post: 31st Jan 2009, 17:53
