  1. Member Ar'ina's Avatar
    Dec 2007
    Portugal
    Hi, i'm new here , i dont know if this is in the right place, if not i'm sorry
    Someone can tell me please how can i close GOPs in PGCDemux (if possible)?
    thanks
  2. Banned
    Jun 2007
    UNREACHABLE
    Hi there ^_^
    The GOPs are made closed or open during the encoding phase,
    so you'll have to re-compress your video with your mpeg-encoder
    set to generate closed GOPs.
  3. Member Ar'ina's Avatar
    Dec 2007
    Portugal
    Hi Midzuki, thanks for the help
    In that case i think i cannot do anything
    What i want to do is a dvd re-authorig. I demuxed the dvd vobs to get the video and audio files (m2v and ac3). To do that i used PGCDemux, but when i put both the video and audio files into dvdlab pro i got a warning about open GOPs
  4. Banned
    Jun 2007
    UNREACHABLE
    Ignore that warning and go ahead. Closed GOPs are strictly-necessary
    only for multi-angle stuff.
  5. Member Ar'ina's Avatar
    Dec 2007
    Portugal
    I did what you said... The dvd played perfectly in dvd player
    Thank you again Midzuki
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you are using version 2.x of DVD Lab Pro you can turn the warning off under
    Project -> Properties -> Advanced Tab -> Untick Warn if Open GOP Detected
    Read my blog here.
