I'm a Canadian and I bought my laptop in Canada. It's an Acer Aspire 5630 with windows vista as it's operating system. (I'm not very computer savvy, so that's about all the info I can give you about it.) I have recently moved to Thailand. VCDs are very widespread here and, as they are cheaper to buy and don't have regional codes as DVDs do, I'd like to start using them. I bought a VCD the other day, but windows media player won't run it for me. I have tried downloading Winamp 5.51. It gives me very choppy sound and no picture. To be perfectly honest with you it totally confuses me. My computer geek friend couldn't get it to run for me either and he blamed it on the fact that I have Windows Vista. Is there something that I can download that will let me watch VCDs with Windows Vista?
Take a look at VLC freeware: www.videolan.org/
Plays just about anything, including VCD, and provides its own codecs.
NOTE: During installation, you will be given the option to associate VLC with playback of dozens of file types. You may want to uncheck the association options (video and audio) while you give VLC a try. If you go with the default, you will find most (if not all) your video and audio files will use VLC to open them. This may not be what you prefer.
Another freeware option: www.geocities.com/lalimsoftware/
This software author has several different video players available, including a VCD player: www.geocities.com/lalimvcdplayer/index.html -
Laptop unable to play DVD-9
By LadyMiir in forum Software PlayingReplies: 8Last Post: 6th Jun 2011, 07:52 -
Play AVCHD disk on laptop
By aboveice in forum Authoring (DVD)Replies: 2Last Post: 1st Jul 2009, 04:34 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 21:23 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
Play movies from laptop to TV
By jhebi in forum Newbie / General discussionsReplies: 9Last Post: 3rd Aug 2007, 14:08
