I have a commercial DVD which on play throws up a language selection menu, and then starts the movie with the selected sub. There is a root menu present, but this doesn't load automatically at startup. I never want the subs, so I'd like to change it to load the root menu at startup. It seems I have successfully disabled the loading of company logos, copyright warnings, etc. but I can't for the life of me find any way of swapping startup from the subpicture menu to that of the root menu, and hindering the subpicture menu from loading renders the disc unplayable.
Surely this swap can be done by changing a few of the IFO parameters? Anyone know WHICH parameters these are?
Edit: Ok, found it. Must have been snow-blind yesterday...
For anyone wondering: it's located in the VIDEO_TS.IFO -> VMGM PGCI UT -> LU_1 (language) PGC-Menu_1 -> PGC Command Table -> 1.Post Command --- entering hex: [30 06 00 01 01 83 00 00] here loads the root menu, cancelling the pesky language selection process & language specific copyright warning.
Results 1 to 1 of 1
Lg-bd630 stutter problem solved!
By RogerTango in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Feb 2012, 14:18 -
Pinnacle DVD menu green screen SOLVED!
By Surg1951 in forum Authoring (DVD)Replies: 2Last Post: 27th Feb 2011, 15:12 -
Problem with Avi-MuxGUI in Windows7 -Solved
By netmask56 in forum Video ConversionReplies: 0Last Post: 20th Jul 2009, 04:04 -
Changing a 4:3 menu to 16:9 using ifoedit
By NBninja8 in forum Authoring (DVD)Replies: 4Last Post: 20th Jan 2009, 20:11 -
solved -edited menu wrong size in dvd player (pgcedit)
By spiritgumm in forum Authoring (DVD)Replies: 3Last Post: 9th Oct 2007, 00:00
