Hi,
I recorded some episodes of a tv series from a dvd recorder and I would like help on how I could remove commercials. These individual episodes are in vobs.
Are there free tools that I can use that do not require demuxing?
Thanks in advance !!
Results 1 to 11 of 11
ok... tried mpeg2cut2 but noticed that when i played the clip (in mpeg2cut2 even before doing any cutting or editing) the audio is out of sync with the video....
but when i played the same clip on media player classic it's ok...
am i doing something wrong in mpeg2cut2?...
MPEG Video Wizard DVD is good for what you want to do. I've used it with no synch issues.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
hi daamon,
thanks for the reply...
as i'm doing this as a one-off thing, i'm looking for a more "cost-effective"software...
I use DVD Shrink in reauthor mode and select what I want to keep, instead of what I want to remove. It turns each clip into a separate title instead of chapter, but it plays the same in most players. I believe it will only cut on I frames, so your time resolution is only about half a second (assuming a GOP of 15).
Originally Posted by rancid
I haven't used that tool, but go ahead and use it.......play the edited file in MPC and find out how it sounds. One time on the cheap and I would guess that you will never author and burn to DVD.
What do you have to lose? -
Originally Posted by rancidWant my help? Ask here! (not via PM!)
...or just reauthor with TDA - You can edit out what you don't want. 30 day trial available.
/Mats -
hi SmokieStover,
i was worried that the out-of-sync may affect the eventual cutting and editing... but will give it a try... thanks...
hi lordsmurf & mats.hogberg,
will also try out the trails... thanks !
demuxing VOBs with VobEdit
By siluet in forum Newbie / General discussionsReplies: 13Last Post: 22nd Nov 2012, 16:57 -
Best way of cutting out commercials in H264 TS file ?
By boulder in forum DVB / IPTVReplies: 7Last Post: 4th Jul 2012, 06:14 -
Editing Commercials
By Jacks_Daddy07 in forum EditingReplies: 2Last Post: 18th Oct 2010, 23:09 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10
