Is there are simple Blu-ray / HD-DVD ripper out that can simply extract the desired Video and Audio stream to a single file (for playing off the PC)?
Nathan
FYI I've got a combo Blu-ray / HD-DVD drive and Any DVD HD so I can copy the entire disk but I just want the main movie as I can do with DVD Decrypter on DVD's
In most cases, MP2 or VC-1, there is just one key m2ts file of perhaps 15GB+, in others two of perhaps 10-12GB. It's usually obvious .... but not always. I would love to understand Blu-Ray PGCs too!
Since both HD-DVD and Blu-ray are the same video formats, is there a program that can convert from one format to the other by changting the file structure without re-compressing??
Blu-ray individual a/v/sub streams size tool
By Ennio in forum Blu-ray RippingReplies: 3Last Post: 4th Oct 2011, 00:30 -
Easy way to extract (demux) audio tracks from Blu-ray folder?
By ricsee in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2011, 11:12 -
Problem backing up Blu-Ray using BD Rebuilder with milOtis method
By TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 14:43 -
What is best method of converting Blu-Ray to MKV?
By leejayd in forum Newbie / General discussionsReplies: 11Last Post: 12th Apr 2010, 15:46 -
Ripping Audio streams from Blu-ray?
By MrBlueSky in forum Blu-ray RippingReplies: 3Last Post: 10th Feb 2010, 16:10
