Hello! Does anyone know if the program HDTVtoMPEG2 will convert HD DVD (movie files) to MPEG2? For reauthoring on a DVD+/-R ?
I want to backup my new HD DVDs, but until blanks are cheaper, I'd be okay with just backing them up on regular blank DVD media.
Thanks!
Chris
Results 1 to 9 of 9
No, the files are in a different format.
And that's not "backing up", that's just copying. A backup copy is true to the source. What is the point of taking a HD copy of a movie and converting it down to SD as a "backup"? It defeats the whole point of buying HD.
There is a whole forum here dedicated to DVD/HD-DVD/Blu-Ray.Google is your Friend -
Of course you can get a HDVD burner and $15-$20 discs, if you can find them. Stick with SDVD for now and save yourself many headaches and bucks.
And you will not find a HD-DVD burner because there is only one yet, coming in a Laptop from Toshiba...............
*** Now that you have read me, do some other things. *** -
SDVD???
I would prefer HD-DVD content on DVD± DL.
I'm guessing that the original poster has invented his own abbreviation and just assumes that the entire world knows what it means. Unfortunately, that happens at the time here.Originally Posted by [_chef_
HD-DVD specs support this. I have an example of such a disc and it plays fine.Originally Posted by [_chef_ -
Does anyone know Mr Cooley's (the author) email address or can anyone suggest why, irrespective of the content of the ts file, all I ever get is:
"HDVDtoMPEG2 has stopped working....close the program"
Convert HDTV ts files to DVD mpeg or Avi
By kenmo in forum Video ConversionReplies: 5Last Post: 6th Nov 2011, 09:17 -
HDTV to MPEG (with IVTC) - simplest option?
By Tiernan in forum DVB / IPTVReplies: 8Last Post: 6th Aug 2009, 12:58 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 21:43 -
I need a program to capture Pinnacle HDTV Pro Stick
By hpcampr in forum Capturing and VCRReplies: 8Last Post: 24th Jan 2008, 16:32 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 00:32
